retain feature data types through to writer
  • Jan 6, 2015 2:18 AM UTC
  • 47 views
I am running a workflow using various transformers on data (eg. BulkAttributeRenamer, AttributeCreator etc) is there a smart way to retain the feature data types through to the writer?
When connecting the writer, I copy attibutes from the previous transformer and it lists all columns as "text" "200". I do not want to have to manually change the type in User Attributes.
Cheers!
gio
Forum|alt.badge.img+15
  • Jan 6, 2015 10:32 AM UTC
You could use Schemareader and or SchemaMapper (?)
fmelizard
Forum|alt.badge.img+22
  • Jan 6, 2015 11:12 AM UTC
Hi
You can try and copy from a feature type insetad of a transformer. this will preserve the data types, but if the output attributes do not exist you'll have to manually add them.
Itay
