Restricting files read from zip
  • Aug 17, 2016 2:24 PM UTC
  • 7 replies
  • 55 views
mappymatty
Forum|alt.badge.img+4
Apologies if this question is a bit newby...I'm only an occasional FME user...
I've downloaded a zip from Ordnance Survey containing .csv files called, for example,
HP40.csv
HP60.csv
HT82.csv
HT84.csv
SE00.csv
SE02.csv
SE04.csv
SD06.csv
SD08.csv
TA00.csv
TA02.csv
I have a CSV reader looking in
C:\\OS_Open_Names\\Latest_Source\\*.zip\\**\\DATA\\*.csv which will read all the .csv files.
Is there a way I can update a single reader to read only the SE, SD and TA files?
Thanks
erik_jan
Forum|alt.badge.img+26
  • Aug 17, 2016 2:29 PM UTC
Yes, I think you can using this as the Reader source:
C:\\OS_Open_Names\\Latest_Source\\*.zip\\**\\DATA\\S*.csv,C:\\OS_Open_Names\\Latest_Source\\*.zip\\**\\DATA\\T*.csv
  • Aug 17, 2016 2:35 PM UTC
Hi @matt_yw, this filter expression could also work.
C:\OS_Open_Names\Latest_Source\*.zip\**\DATA\{SE,SD,TA}*.csv
See also here: Directory and File Pathnames Reader Parameters | Special Characters Supported in the Path Filter
mappymatty
  • Aug 17, 2016 3:52 PM UTC
Thanks @erik_jan
mappymatty
  • Aug 17, 2016 3:53 PM UTC
Thanks @takashi for the answer and the link to the documentation.
mappymatty
  • Aug 18, 2016 2:35 PM UTC
I couldn't get this approach to work in the end - it only seems to work if it's folder names within the {}. For files I think I need to use the approach @erik_jan  proposed.
mappymatty
  • Aug 18, 2016 3:24 PM UTC
Seems to require , instead of ;
erik_jan
  • Aug 18, 2016 4:05 PM UTC
Sorry, you are right. I will change this in the answer.
