Reading Multiple text files
  • Jan 10, 2018 2:57 PM UTC
  • 61 views
I have an attribute called text_lined_data that contains 6 data columns. How do i extract that information into 6 columns and line one as header?
danilo_fme
Forum|alt.badge.img+58
  • Jan 10, 2018 3:51 PM UTC
Hi @mortenag,
Could you share this sample data?
Thanks,
Danilo
danilo_fme
  • Jan 10, 2018 3:55 PM UTC
Are you reading a CSV file?
jdh
Forum|alt.badge.img+41
  • Jan 10, 2018 4:16 PM UTC
Instead of using a text reader, try using a CSV reader with the separator character set to ;.
If that's not possible, and the header is always consistent, you can skip the first feature, and use an attributeSplitter on the text_line_data, (;) and then manually rename the resultant list to the correct attribute names.
