Readers and Schemas
  • Oct 23, 2017 9:56 PM UTC
  • 6 replies
  • 121 views
dbklingdom
Forum|alt.badge.img+7
I have a folder full of unzip (.shp) mixed shape files Points, Lines, and Polys. Can I read in only the points somehow?? If not can anyone recommend a way to restrict to schema to only that of the point shapes, which I have found two different ones so far?
Best answer by takashi
Hi @dbklingdom, I would try this.
  1. Read schema features from the target *.shp files with the Schema (Any Format) reader. Expose "fme_geomatry{}" and "fme_dataset" in the "schema" feature type.
  2. Use the Tester to select only schema features having value "fme_point" in the "fme_geometry{0}".
  3. Read the point Shapefile datasets using the FeatureReader with setting "fme_dataset" to the Dataset parameter.
trentatsafe
Hello @dbklingdom ,
A quick way that I can think of would involve using a Merged Filter on your Shape reader(if the point shapefiles have a different naming convention you could filter here eg: '*_point'). Alternatively, if you read in all of the Shapefiles and use a GeometryFilter. You could then allow only the point features to be passed on to the rest of the translation. I hope that helps.
Documentation that may help can be found here:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/!FeatureTypeProperties/Merging_Feature_Types.htm
https://docs.safe.com/fme/2017.1/html/FME_Desktop_Documentation/FME_Transformers/Transformers/geometryfilter.htm
I hope that helps.
  • Oct 23, 2017 10:31 PM UTC
dbklingdom
  • Oct 24, 2017 5:16 PM UTC
How to query schema in FeatureReader for geometry type. I have 12 different schema's and maybe more coming from shapes. i would like to use the Schema's of the points, but cannot seem to get fme_geo or shape_geo in the Schema output to tester.
  • Oct 25, 2017 9:04 AM UTC
This screenshot illustrates my intention.
Forum|alt.badge.img+63
A very elegant solution!
dbklingdom
  • Oct 25, 2017 6:20 PM UTC
Hey many thanks for the replies. Now on the other side how do we setup FeatureReader to output the Schema and data?? If not there I have sent schema to listExploder, but am have trouble setting the schema up to be reader by the Dynamic Writer. IS it a single field? what is the Concatination syntactic? Thx
