Read GeoPDF as a single PDF and not split into rows.
  • Mar 22, 2018 5:48 PM UTC
  • 134 views
Hello all,
I am reading a scanned PDF image of a county and I would like it to read as a single file. It appears to be reading it as 7 different files, which will output into 7 different TIFFs.
Does anyone know how to fix this problem and make it read as a single PDF image?
Best answer by jakemolnar
Have you tried the non-spatial mode "Read Rasterized Pages"?
You can render the entire page as a single raster with this option, at the size of your choice. I recommend the "Scale" mode.
edit: Oh also, I just thought I'd add: the reason you're seeing 7 different "files" is probably because your PDF embeds 7 different images. In spatial modes, every object in the PDF file is emitted separately. In non-spatial modes, there is generally one feature per page instead.
jakemolnar
  • Mar 22, 2018 6:03 PM UTC
  • Mar 22, 2018 6:21 PM UTC
Awesome! Thank you very much, this worked perfectly!
Next time ill try reading the documentation a little better.
jakemolnar
I'm glad it worked out for you!
PS. In case it isn't clear in the documentation, the scale (pixels per point) is kind of like a "zoom" parameter. Alternatively, if you know exactly the dimensions of the raster you would like to create, then you can use the "custom" raster size mode.
billmcbride
Forum|alt.badge.img+4
  • Sep 1, 2023 3:56 PM UTC
new user here: would someone suggest the range and settings of the RasterCellValueReplacer and the RasterAndNoDataSetter that would yield a GeoTiff that will satisfy the input conditions for the CADRG converter. I read the docs, but don't understand the use of these two transformers yet.
