Read esri Shapefile from FTP
  • Jun 23, 2021 3:55 PM UTC
  • 85 views
francis_m
Forum|alt.badge.img+9
Hi FME users! I have to read some ShapeFile from FTP.
I use a FTPCaller to get all the files that I need, and then user a FeatureReader to read ShapeFile directly from FTP. I can get the geometry, but not the attributes...
Do you know why if I read from FTP, no attributes are read but only geometry ?
Thank you for your help!
Francis M.
danilo_fme
Forum|alt.badge.img+58
  • Jun 23, 2021 11:07 PM UTC
Hi @francis_m​
Could you share us the Workspace?
Thanks in Advance,
Danilo
caracadrian
Forum|alt.badge.img+23
  • Jun 24, 2021 5:31 AM UTC
Mostry your "error" if from the fact that ESRI Shape is a collection of files, not just the .shp
You need to fetch every component of that collection (.shp, .shx, .dbf, .prj, .cpg) that correspond to the shape filename.
francis_m
  • Jun 28, 2021 2:24 PM UTC
Hi @francis_m​
Thanks in Advance,
Danilo
Sorry, I can't share, but I've been able to accomplish the task by downloading first all the files of the shapefile. But I was hopping FME would read a shapefile, even on a FTP site, as I was using a Shapefile reader. Anyway... I did it by downloading first, then read it... thanks!
francis_m
  • Jun 28, 2021 2:25 PM UTC
Thanks, that's what I was thinking... and did. But, as I used a Shapefile reader, I was thinking that FME would have read all the file for the shapefile format. thanks!
