Problem opening reader for Intergraph GeoMedia Access Warehouse
  • Jul 17, 2013 7:43 AM UTC
  • 60 views
vki
Forum|alt.badge.img+8
Hi
We have a GeoMedia Access Warehouse with about 170 tables in it. When we try to add a reader to this warehouse, we got an error-message:
GeoMedia Reader: Reading from GeoMedia Access Warehouse version 5 or better
Database error: '[Microsoft][ODBC Microsoft Access Driver] Too few parameters. Expected 1.'
SQL is: ' SELECT "csguid","basestoragetype","geodeticdatum","ellipsoid","projalgorithm","zone","falsex","falsey","latoforigin","lonoforigin","hemisphere","latoftruescale","scalereductfact","standpar1","standpar2","stor2compmatrix1","stor2compmatrix6","stor2compmatrix13","stor2compmatrix14","stor2compmatrix15","azimuthangle" FROM "GCoordSystem"'
Successfully closed GeoMedia Access Warehouse reader
Adding readers to Warehouses with less tables works fine.
Are there too many tables in the warehouse?
Thanks in advance
Vera
Best answer by fmelizard
Hi Vera,
I tried this myself by reading an Access Warehouse with 180 tables. Seemed to work fine - so I guess there is something else going on. I'd suggest you send this data to support if possible - either through your FME partner or to safe.com/support. The FTP details can be found on the support form.
Thanks
Ken
fmelizard
Forum|alt.badge.img+22
  • Jul 18, 2013 8:12 AM UTC
Hi Vera,
Thanks
Ken
