Powerlines from Lidar
  • Mar 30, 2020 8:34 AM UTC
  • 88 views
alfons
Forum|alt.badge.img+7
Hello,
I have a LIDAR test data set, where I am trying to determine the power lines. These are currently in class 0 (unclassified). My first approach now is to select all points with a certain height above ground (and class 0). If the classification 0 is possible without problems, I unfortunately fail because of the classification of the points with a certain height above ground. For this purpose I have calculated a grid with the points of class Ground and the SurfaceModeller and then I check if the points of class 0 are on the grid height. If this is not the case, I continue to use them - but that is not possible.
Another problem (which I haven't investigated yet) is, how do I convert the selected points into a vector?
Is there another approach to extract (power) cables from lidar data?
Could you maybe use a spatial analysis like density or cluster analysis to determine the path of highest elevations?
erik_jan
Forum|alt.badge.img+26
  • Mar 31, 2020 6:45 PM UTC
I think the person to reach out to is Dmitri Bagh (@dmitribagh), from Safe Software.
He created some similar FME templates in the past.
Hope he can help you.
