POSTGIS Feature Writer in FME Workbench 2016 : Where do I set the TRANSACTION_INTERVAL?
  • Aug 4, 2017 2:46 PM UTC
  • 47 views
fmelizard
Forum|alt.badge.img+22
  • Aug 4, 2017 3:40 PM UTC
Hi @grumblyfrown, you can set the Features Per Transaction in the Navigator, under the parameters for the PostGIS Writer.
  • Aug 8, 2017 3:15 PM UTC
Hi and thanks! However, this is not available with the FeatureWriter transformer which is what I need to use (I think :-)!)
fmelizard
  • Aug 8, 2017 4:02 PM UTC
Hi @grumblyfrown,
If you're running FME 2017.0 or higher, you can set the Features per Transaction in the FeatureWriter from the parameters dialog.
fmelizard
  • Aug 8, 2017 7:11 PM UTC
Hi @grumblyfrown,
Sorry, I missed you in my response! @g1 please check out the FeatureWriter in FME 2017.0
