post to fmepedia
  • May 29, 2014 2:04 AM UTC
  • 5 replies
  • 63 views
darkspatiallord
Forum|alt.badge.img+8
Hi
Can you use a Case Changer on an unexploded list.
So all values within that list are put to the same case so it makes it easier for ListSearcher queries to work (or can I do something in the ListSearcher to make this happen)
DL
  • May 29, 2014 5:14 AM UTC
The ListSearcher seems not to have case insensitive option.
A workaround I can think of is:
1) Concatenate the list using the ListConcatenator.
2) Change case of the concatenated string using the StringCaseChanger.
3) Transform the concatenated string into a list using the AttributeSplitter.
4) Then, apply the ListSearcher.
Alternatively, a Python or Tcl script could be an effective solution for searching a matched list element in the condition of case insensitive.
Takashi
gio
Forum|alt.badge.img+15
  • Jun 2, 2014 10:08 AM UTC
ListSearcher regular expression is strangely limited. It does not accept a lot of switches. One of those is the nocase switch. Alas.
The switches do work if u use listsearcher tcl in a attributecreator or expressionevaluator
[regexp -nocase -all -inline {@Value(expression ()) } @Value(Attribute)]  or something like that.
  • Jun 2, 2014 10:39 AM UTC
For example, the TclCaller with this script extracts first matched element and index in the list with "_pattern" in case-insensitive manner.
proc searchList {} {
   set values {}
   for {set i 0} {[FME_AttributeExists "_list{$i}"]} {incr i} {
       lappend values [FME_GetAttribute "_list{$i}"]
   set index [lsearch -exact -nocase $values [FME_GetAttribute "_pattern"]]
   if {0 <= $index} {
       FME_SetAttribute "_first_matched_element" [lindex $values $index]
   return $index
gio
  • Jun 2, 2014 11:00 AM UTC
mailto insertion...how do i prevent this postingsystem doing that?
  • Jun 2, 2014 11:11 AM UTC
Gio, try use "Add a code smple". I've never used it...
