points to topojson
  • Jul 17, 2020 7:30 PM UTC
  • 47 views
I
I am trying to convert the attached shape file to topojson. it is a shapefile of points. It seems some of the points are causing a problem when converting because I can take a sample and create the topojson file. I can't seem to figure out the problem with the offending points. Appreciate any help. Thanks.
David
  • Jul 20, 2020 12:47 PM UTC
Hi @spiller, I was able to reproduce an error with your sample Shapefile dataset and the TopoJSON writer. I would recommend you to send the dataset to Safe and ask them to clarify why the writer raises the error.
  • Jul 20, 2020 8:29 PM UTC
Ok. Thanks.
