PNG-writer prints out extra PNG-files
  • Sep 21, 2018 1:40 PM UTC
  • 35 views
Hi!
I am trying to tile some PNG:s with the WebMapTiler. My problem is when writing the data to PNG-format the writer put extra "_1" to some of the tiles.
The fanout is @Value(_zoom_level)/@Value(_tile_column) and when I inspect the objects just before the writer no object has any "_1" as fanout. But when the writer writes data to my folder it divides some of the PNG:s into two, like this:
Does someone know why the writer prints PNG:s with the "_1"-ending?
Best answer by david_r
My guess is that there are several rasters with the same fanout value hitting the PNG writer, which will make FME append a counter to the filename to avoid overwriting existing files.
Try passing all the fanout values through a DuplicateFilter and see what happens.
  • Sep 21, 2018 1:43 PM UTC
