PNG Reader Problems
  • Sep 25, 2019 9:38 AM UTC
  • 54 views
i need some help to read and write PNG File with GRAY8 band.
if i use the normal PNG Reader then i got a fully black image.
i experiment a little bit with the raster and rasterband transformers, so that i got a nearly good solution, but not the same as i open the file with paint.
in attachment there are 2 example files and my current experiment bench.
can someone help?
Forum|alt.badge.img+54
  • Sep 25, 2019 9:47 AM UTC
Take a look at the RasterBandInterpretationCoercer, the destination Interpretation Type depends on what you are doing with the data, scale by data values
it could be so simple :-)
thankyou
