Performance Issues with extracting a large number of points from 1m LIDAR
  • Feb 19, 2015 4:48 PM UTC
  • 51 views
dfresh
Hello,
I am having some more performance issues with the workflow displayed below,
basically my inputs are
  • ~11 TB 1m Lidar Surface
  • ~500,000 - 3,000,000 points
and goal is to extract elevation values using average 4 of average 16.
Original, I just had the LIDAR reader directly connected to the PointonRasterExtractor
but that caused memory issues
I have taken these steps so far
  • Added a bounding Accumlator
  • Dissolver into 1 feature
  • Clipper to extract only the areas of LIDAR I need
  • Than extracted the points
I am open to any other solutions anyone might have to increase the performance
  • Feb 20, 2015 5:37 PM UTC
So, if I'm getting this right, you're trying to extract the values from the Lidar Raster (which is 11TeraBytes in size!) at any given point (of which you have a few million)?
With those data quantities you're going to have to do a *lot* of optimisation.
You're kind of on the right track, but only just starting.
Suggestions:
1) Your attempt to get a subset of the lidar data is suboptimal. Instead, take the BBoxAccumulator, and then follow with a FeatureReader, setting it to only select features within the bbox. This reduces the data read in the first place, and removes the need for a clipper too, further benefiting.
2) Use FME 2015; historically Safe are good at ensuring each version is faster than the last, so it may help.
3) Then it gets a little more tricky. It depends on the distribution of the points and the data structure. If the points are in groups (ideally spatial, but potentially attribute based), I would suggest splitting them up somehow, and using WorkspaceRunner to process the subsets. This can massively speed things up, even if you only run one child process at a time.
Those should be enough to get you started; but the core is: split the dataset as much as possible and only process small subsets at a time.
See how far you get and update here if it's still slow after some more fiddling.
Cheers,
Jonathan
(P.s. Note: I'm not sure you ever needed the "Dissolver" there, as the output for the BBoxAccumulator should be a single box).
