order of fgdb fields
  • Oct 8, 2013 5:52 PM UTC
  • 38 views
owen
When creating a new file geodatabase feature class from an existing schema, native fields such as SHAPE_Length are appended to the end of the table, ie the last column.
Since it is possible to add new fields in arc, but not reorder them permanently, I am struggling to work out how to replicate a schema exactly where these fields are not at the end.
Any ideas?
fmelizard
Forum|alt.badge.img+22
  • Oct 8, 2013 8:29 PM UTC
Hi Owen,
Have tried using a template XML file? That will enforce the esri software to create the schema.
Hello Owen,
in my case it worked well with the template file. Here is a link, where it is explained:
http://fmepedia.safe.com/articles/Samples_and_Demos/Creating-Geodatabases-based-on-existing-geodatabases
Best regards,
Stefan
owen
  • Oct 9, 2013 8:26 AM UTC
excellent, thank you both very much
