OneDriveConnector User Last Modified
  • Dec 17, 2019 4:14 PM UTC
  • 5 replies
  • 73 views
runneals
Forum|alt.badge.img+32
Is there a way to get the Modified By username/name from One Drive?
Best answer by jlutherthomas
Hi @runneals
Looks like Graph API does support it: https://developer.microsoft.com/en-us/graph/graph-explorer
OneDrive > Recent files > Response Preview
I would recommend using the HTTPCaller if the OneDriveConnector doesn't support it.
"lastModifiedBy": {
                "user": {
                    "email": "MeganB@M365x214355.onmicrosoft.com",
                    "displayName": "Megan Bowen"
sigtill
Forum|alt.badge.img+25
  • Dec 20, 2019 2:33 PM UTC
Hi @runneals I think you need to use the Microsoft Graph API and check if that has the desired parameters: https://knowledge.safe.com/questions/76488/connection-to-microsoft-graph-api.html
runneals
  • Dec 20, 2019 10:02 PM UTC
I'm using that, but the one drive connector doesn't seem to support it I guess :/
Hi @runneals
"lastModifiedBy": {
                "user": {
runneals
  • Dec 26, 2019 7:52 PM UTC
Hi @runneals
"lastModifiedBy": {
                "user": {
How hard is it to get integrated to the current OneDriveConnector transformer? That would be ideal if all the attributes came through.
@runneals
We added an option to return the original response of the list request for the List Action in the OneDriveConnector. In the JSON object returned via the new output attribute, you will find the "lastModifiedBy" key.
This is available in FME 2020 b20177 and higher.
