Offset the center point of the segment perpendicular to the segment
  • Oct 22, 2022 12:33 PM UTC
  • 123 views
boubcher
Forum|alt.badge.img+11
I extracted the center point of a line segment, I need to offset this point from its original position on the line to a 10m distance from the line and should be perpendicular to the line
tomfriedl
Forum|alt.badge.img+14
  • Oct 24, 2022 8:08 AM UTC
  • first make a parallel line: OffsetCurveGenerator
  • then find the center: CenterPointReplacer
geomancer
Forum|alt.badge.img+71
  • Oct 24, 2022 11:08 AM UTC
Or you can use some math:
Offset_from_Line
geomancer
  • Oct 24, 2022 1:06 PM UTC
@nielsgerrits​ added and subsequently removed a reaction mentioning the Labeller. This seems to be a viable alternative, as long as the sign of the Label Offset is set depending on the direction of the line. The resulting coordinates are exactly the same as in my math solution described above. Kudos to @nielsgerrits​!
Offset_from_Line_using_Labeller
nielsgerrits
Forum|alt.badge.img+67
:) thanks, I had not enough time to work it out properly as you did.
