More accurate line length using elevation / DEM
  • Aug 29, 2016 9:31 PM UTC
  • 69 views
fmelizard
Forum|alt.badge.img+22
How can I calculate a more accurate line length using a DEM?
Best answer by fmelizard
There are probably a few ways to do this, but here is one way.
Chopper —> PointOnRasterValueExtractor —> 3DForcer —> PointConnector —> LengthCalculator
  1. Chopper: split the line into points (max vertices = 1)
  2. PointOnRasterValueExtractor: get the elevation from the raster to the points.
  3. 3DForcer: force the point features to use the elevation as the z component.
  4. PointConnecter: connect the points into a line again.
  5. LengthCalculator: calculate the length using all three dimensions.
I wonder how others are doing this?
fmelizard
  • Aug 29, 2016 9:35 PM UTC
daveatsafe
Forum|alt.badge.img+24
  • Aug 29, 2016 9:51 PM UTC
Conform the lines to the DEM surface with the SurfaceDraper before measuring the length with the LengthCalculator.
