Microstation DGN V7 - Writing dimensions
  • Jan 15, 2017 7:25 PM UTC
  • 77 views
amgaad
Forum|alt.badge.img+3
I am creating a process to 'clean up' our microstation v7 dgns - remove duplicates, unwanted data on wrong levels etc.
When I read the v7 dgns then write back to v7, I am losing any dimensions. They are changing from idgs_element_type 33 (dimension) to 4 (lines).
I have the 'drop dimension' unticked.
Has anyone experienced anything like this? Am I doing something wrong?
Any help would be really appreciated.
KR
Amgaad
daveatsafe
Forum|alt.badge.img+24
  • Jan 18, 2017 7:10 PM UTC
Hi Amgaad,
This is an issue we should look further into in FME Support. Please send a copy of your Microstation file and workspace to support@safe.com, and I will try to find the source of the problem for you.
amgaad
  • Jan 20, 2017 8:04 AM UTC
Hi Amgaad,
Thanks very much @DaveAtSafe I'll send the files across as soon as I can!
