Merge topology of each floor on ifc
  • May 19, 2020 2:39 PM UTC
  • 36 views
Hi, I am working with an ifc extension file containing 11 floors. I worked with separate workspaces for each floor and created their topology. I want to calculate the shortest path in the building. For this, I have to combine the topology of each floor with stairs, how can I do this?
Since the nodes created for topology slowed down the system, I had to work on each floor separately.
daveatsafe
Forum|alt.badge.img+24
  • May 19, 2020 3:31 PM UTC
Hi @glshayaz,
I don't think there is an easy answer to this - the ShortestPathFinder only works in 2D.
I think you will need to find the shortest path to each elevator/stairwell on your initial floor, then the shortest paths from each elevator/stairwell on the destination floor to the destination. Combine the path length for each elevator/stairwell, then determine the overall shortest path from those lengths.
