Merge borering shape files with diferent names
  • Mar 12, 2019 3:05 PM UTC
  • 67 views
aron
Forum|alt.badge.img+16
I have a dataset with a large number of areas (tiles) that border each other. Each area contains a large number of shape files. Each area folder holds the same types of data. All files have unique names.
They have the following syntax: area_datatype.shp.
I would like to merge all the files of a similar datatype into one. So instead of having X areas with Y shape files in each I would like to have Y shapefiles covering all areas X.
The standard procedure is to build a dynamic work space and use fme_feature_type for the output, but I can't get it working this time. My guess is that I somehow need to pull the name of the data table, if that is possible? Or is there some nifty setting that I might have missed?
Any advice on how I can get this to work?
  • Mar 12, 2019 3:30 PM UTC
I think you could still use fme_feature_type as the schema definition name, if you defined the destination Shepefile name with other attribute e.g. "_filename".
In the dynamic writer feature type, set fme_feature_type to Schema Definition Name explicitly and set the destination file name to Shapefile Name, as in:
aron
  • Mar 13, 2019 8:36 AM UTC
Thanks @takashi!
A follow up question: How do I expose _filename? I can not find anywhere to expose this attribute.
Edit: I figured it out on my own. FilenamePartExtractor to the rescue.
  • Mar 13, 2019 8:40 AM UTC
"_filename" is just an example. You can specify any attribute which stores your required destination Shapefile name.
