line to mesh
  • Sep 17, 2015 1:16 PM UTC
  • 89 views
zzupljanin
Forum|alt.badge.img+5
Hello,
is there a way to convert polygonal entity (geometry) into a surface or mesh or face?
thank you
Best answer by zzupljanin
Anyway, the problem was in geometry of polygons. Some of them weren't closed (having the same coordinates of start and endpoint). Puting in CoordinateExtractor for startpoint and endpoint, then using Tester (if they are same) I've managed to flag those problematic ones. For them, I used VertexAdder at the starpoint (so that it gets closed) as endpoint. Afterwards I've just put FaceReplacer and got everything worked.
  • Sep 18, 2015 6:05 AM UTC
Hi, can the FaceRepalcer help you?
Takashi
zzupljanin
  • Sep 18, 2015 6:25 AM UTC
I shoul have specify problem better: I have polygonal facades of building looking like this
so when I use facerepacer it goes rogue:
zzupljanin
  • Sep 21, 2015 10:05 AM UTC
