LAZ 1.4 is not yet supported ... when will it be ? ... LAZ 1.4 was released in march on https://laszip.org/
  • May 31, 2018 1:01 PM UTC
  • 14 replies
  • 158 views
mriedo
Participant
Version 2018 of FME supports LAZ 1.1, 1.2, 1.3 but not LAZ 1.4 that was released on https://laszip.org/
Best answer by fmelizard
Hi @mriedo, our very latest FME 2018.1 betas now have support for LAZ 1.4. Download the beta here to try it out!
mriedo
Participant
  • Participant
  • May 31, 2018 1:03 PM UTC
A lot of LIDAR users are now using LAS 1.4 that has large benefits over older LAS versions ... and it would be great FME supports the new compression LAZ 1.4 format
see : https://www.usgs.gov/faqs/how-do-i-access-usgs-lidar-data-laz-14-format
mriedo
Participant
  • Participant
  • May 31, 2018 1:22 PM UTC
I tried with FME 2018.1 beta build 18462 ... and it's not yet supported
message from FME :
LAS writer: Compression is not currently supported for point format 7. The file will not be compressed. To enforce a point format that supports compression, change the version to 1.4-legacy-compatible or earlier
mriedo
Participant
  • Participant
  • May 31, 2018 1:24 PM UTC
It's not great to go to 1.4-legacy compatible ... as if we do so, we loose information from the LAS 1.4 format
mriedo
Participant
  • Participant
  • May 31, 2018 1:27 PM UTC
I guess FME is using liblas ? ... found this info on https://liblas.org/
As of 2018, libLAS has been replaced by the PDAL project and it is in hibernation or maintenance mode. libLAS does not provide support for LAS or LAZ 1.4, which PDAL does
stalknecht
Forum|alt.badge.img+22
  • Jun 10, 2018 8:44 PM UTC
As a workaround you could use las-tools in a systemcaller to do the decompression and / or compression.
mriedo
Participant
  • Participant
  • Jun 11, 2018 8:45 AM UTC
Thanks for the workaround ... it will help waiting it to be in next FME release with LAZ 1.4 support
fmelizard
  • Jun 22, 2018 10:06 PM UTC
mriedo
Participant
  • Participant
  • Jun 25, 2018 8:18 AM UTC
I tried it out ! It works great. You guys are incredible. Thanks so much !
mriedo
Participant
  • Participant
fmelizard
  • Jun 25, 2018 4:00 PM UTC
Wonderful to hear! Happy FME-ing :)
mriedo
Participant
  • Participant
  • Jul 5, 2018 7:27 AM UTC
After detailed analysis from Martin Isenburg who developped LAZ compression, there seems to be 2 problems with the FME implementation of LAZ 1.4
(1) Unpopulated extended_number_of_points_by_return
(2) Extended classification codes disappear / get remapped.
Could you please get in touch with Martin at info@rapidlasso.com for more information or send me a contact person ?
xiaomengatsafe
Forum|alt.badge.img+11
Hi @mriedo, Thank you very much for your latest feedback here. We appreciate you spending time informing us of these shortcomings. We will be looking into them, and follow up with you.
mriedo
Participant
  • Participant
  • Jul 11, 2018 8:32 AM UTC
The problem 1 was solved in last beta version 18154
The problem 2 was not a bug ... but a bad manipulation on my side
So you can SAFEly use FME to compress/decompress LAZ 1.4
Thanks SAFE !!!
xiaomengatsafe
Thanks SAFE !!!
Thanks @mriedo for the update! The latest beta build 18514 is currently available to download as beta, soon to be released.
