LAS to Custom Text Format
  • Feb 1, 2016 11:19 AM UTC
  • 113 views
i have an LAS file and want to export a custom text file with X Y Z R G B Classification. how would i do this the writer for txt only exports XYZ values and i can't seem to find a way to get this information out of my point cloud.
Best answer by erik_jan
@jamiefinney probably figured out this:
Using the Point cloud XYZ writer you can add components to the output.
See attached parameter settings:
  • Feb 1, 2016 11:35 AM UTC
Ah solved it dind't check the paramters in the output writer.
  • Feb 17, 2016 6:56 PM UTC
hi there,
i do have the same issue as u stated in your first msg.
can u pls clarify how u figured it out? i m new to FME.
erik_jan
Forum|alt.badge.img+26
  • Feb 17, 2016 7:03 PM UTC
