LAS spatial filtering using 3d object
  • Dec 16, 2016 12:53 PM UTC
  • 130 views
Is it possible to spatially filter a LAS file using a 3d object?
I have created a multipatch 3d AOI in ArcGIS expecting to be able to do 3d spatial analysis with it, but appears that LAS datasets cannot be used with the 3d Analyst extension - Inside 3d tool.
Is this possible in FME? I have tried spatial relator but that does not seem to achieve what I am after.
itay
Forum|alt.badge.img+19
  • Dec 16, 2016 1:50 PM UTC
Which FME version are you using? Have you tried the clipper?
  • Dec 16, 2016 2:02 PM UTC
Currently on 2015.1
Would clipper not just clip in 2d though?
itay
  • Dec 16, 2016 7:40 PM UTC
Currently on 2015.1
according to the 2016.1 documentation the clipper accepts point clouds, but I guess that not much help...
https://knowledge.safe.com/articles/1138/transformers-to-use-with-point-clouds.html
erik_jan
Forum|alt.badge.img+26
  • Dec 16, 2016 10:48 PM UTC
The Clipper transformer can be used to Clip pointcloud objects using a 3D box object.
I have seen demo's by @dmitribagh using FME 2014 or so.
