Issues reading sibfolders in FME Server Data folder
  • Apr 4, 2018 7:41 PM UTC
  • 83 views
gboquin
Forum|alt.badge.img+8
Hi, I am trying to read some data that is stored in several subfolders in the FME share resource data folder. It seems like the process didn't like the wild card ie.. Data\\foldername\\**\\*.csv
Any pointers/ work arounds?
Thank you in advanced for any help you can provide.
Best answer by andreaatsafe
Hi @gerry,
Have you tried using forward slashes? The Directory and File Pathnames Reader Parameters documentation suggests to use forward slashes (/) as separators, as they do not conflict with either glob escape characters or UNC path names. Single backward slashes (\\), for example C:\\data\\*.dgn, may be treated as escape characters, leading to incorrect interpretations.
Please take a look at the section Common Path Filter Issues for troubleshooting assistance.
Hope this helps!
-Andrea
andreaatsafe
Forum|alt.badge.img+17
  • Apr 4, 2018 7:52 PM UTC
Hi @gerry,
Hope this helps!
-Andrea
gboquin
  • Apr 6, 2018 1:11 PM UTC
That did the Trick!! thanks so much!!
