Issues Authorizing ArcGIS Online connections in Server 2021.2
  • Nov 22, 2021 4:51 PM UTC
  • 5 replies
  • 179 views
swach
I am setting up a brand new installation of FME Server 2021.2.0.1 and I can't authorize any ArcGIS Online connections. It gives FME Server OAuth Service Failed. It doesn't matter which user I try to authenticate. This works in my other 2019.1 server, so I know these connections should work.
itsmatt
Forum|alt.badge.img+48
  • Nov 23, 2021 1:14 PM UTC
Possibly something to do with the redirect uri in the web connections? Could be that you need to set up a new web connection for the new server.
swach
  • Nov 23, 2021 1:18 PM UTC
Even if I create the connection within the server interface, it gives the same error
nielsgerrits
Forum|alt.badge.img+67
@virtualcitymatt​ is probably right asking to check the redirect url in FME server. Web connections --> manage services. It should be something like "https://my.fme-server.com/fmeoauth". This redirect url should be added to the app in ArcGIS Online as well, as a new server might also be a new adress?
You can always submit a case.
danminneyatsaf
Forum|alt.badge.img+13
@swach​ as @virtualcitymatt​ and @nielsgerrits​ have mentioned, this is most likely a problem with the web service & the Redirect URI setup. I would recommend taking a look at this answer from one of our other Safer's that goes more in-depth on how to set this up properly.
swach
  • Nov 25, 2021 5:28 PM UTC
Yeah, that was the problem. We are now needing to upgrade the server to HTTPS before we can set it up with AGOL so that is the next step
