Is there MITAB Writer support for Korean Language?
  • May 31, 2013 10:56 AM UTC
  • 56 views
jaslee
Participant
I have a workflow which outputs MITAB in several languages: Arabic, Hebrew, Japanese  and Chinese Simplified. These come out fine when I check them in MapInfo using the Microsoft AppLocale tool.
Now I want to add Korean to the workflow but I can't find any option in the MITAB writer Character Encoding list for this language. Could anyone help confirm this is a limitation?
Thanks,
Jason
  • May 31, 2013 11:32 AM UTC
Hi Jason,
unfortunately, the MapInfo TAB writer seems not to support Korean encoding - CP949. FME Readers and Writers (formats supported by FME 2013 SP1) > MapInfo TAB Reader/Writer > Writer Overview > ENCODING
Takashi
  • May 31, 2013 11:53 AM UTC
I will add to Takashi's answer that this seems to be a limitation of MapInfo and their APIs and not the fault of FME.
It seems MapInfo 10 has very limited support for Unicode (if at all).
David
jaslee
Participant
  • Participant
  • May 31, 2013 12:12 PM UTC
Thanks guys. I'm pretty sure MapInfo does supports Korean language, as Takashi mentions CP494 (rather than the more convenient Unicode), but it's a shame there is no direct encoding option in FME's MITAB Reader/Writer.
I think I have a workaround - to output to Shapefile in UTF-8 first then use MI's Universal Translator tool to convert to MITAB with the CP494 encoding.
Jason
