Is there any way to extract the geometry of IfcRelSpaceBoundary in FME?
  • Feb 10, 2020 4:52 AM UTC
  • 104 views
Hello
I could extract the IfcRelSpaceBoundary using the Deprecated reader. However, it doesn't have any geometry. There is an attribute (Connection geometry) which refers to the instance_name of the related geometry but I can't retrieve this geometry. Is there any way to extract the geometry of IfcRelSpaceBoundary in FME?
@daveatsafe
daveatsafe
Forum|alt.badge.img+24
  • Feb 10, 2020 5:55 PM UTC
Hi @mbarzegar,
I don't think those features have geometry, but are just a relationship between the boundary and the Space. In your reader settings, please ensure Read IfcSpace Geometries is set to Yes, then the desired should be on the IfcSpace features.
  • Feb 11, 2020 12:37 AM UTC
Hi @mbarzegar,
Thank you for your quick response. They have an attribute (connection geometry) which refers to their related geometry. Actually I'm trying to extract faces of IfcSpace. I can do it in FME with GeometryCoercer but in order to visualize the results on web, I need GUID. However, the extracted faces with this method have the same GUID and they are not identified as a specific entity type in Ifc. I found that each IfcRelSpaceBoundary is equivalent to each face of the IfcSpace. As you see in Solibri model viewer I could select one face of the IfcSpace which is identified as space boundary and has the same GlobalId. Also, in FZKViewer I can see the attached geometry. Is there any way to extract these geometries as Solibri does?
