Is there a way to improve FeatureWriter speed?
  • Jul 21, 2016 7:52 PM UTC
  • 43 views
I have been testing out the featurewriter transformer to handle data updates, however I have noticed that it is much slower than the equivalent standalone writer. For example, I am trying to write 80000 records to a SQL Server Spatial database table using the featurewriter. This task takes just over a minute (1:27) with the SQL Server Spatial Writer and over 10 minutes with the featurewriter transformer. The parameters are identical with the exception of those that you are not able to set with the transformer (bulk insert, tranaction interval, timeout, etc.). Is this just a flaw of the featurewriter or are there ways to improve the performance of this transformer that I have not implemented?
Thanks
erik_jan
Forum|alt.badge.img+26
  • Jul 21, 2016 8:13 PM UTC
I do not know if this works the same, but I would try setting up a dummy SQL Server Spatial writer (with no feature types to write to) and set the parameters on that.
I know you can influence the Generic writer that way.
I hope that would work for the FeatureWriter as well.
It is worth the try.
