Is it possible to set a Mapinfo file as 'read only' on the writer?
  • Mar 25, 2014 9:15 AM UTC
  • 41 views
Sorry if it's a simple question, but is it possible to specify that a Mapinfo file written from FME is 'read only' in the parameters?
Thanks in advance
Best answer by david_r
I do not think so. You could, however, write a Python shutdown script that does this for you.
See here for a starting point (http://code.activestate.com/recipes/303343-changing-file-attributes-on-windows/).
David
  • Mar 25, 2014 6:49 PM UTC
David
