Is it possible to disable FFS file?
  • Mar 11, 2020 8:41 AM UTC
  • 133 views
jugoslaviaa
Hi all,
I would like to ask whether it is possible to disable the generation of the FFS file. I am running into some storage problems. Therefore, I would like to disable the FFS if it is possible.
Thanks in advance.
Best answer by david_r
Based on your screenshot it looks like temporary files used for generating the final DXF output, i doubt that you can disable those.
  • Mar 11, 2020 9:38 AM UTC
Do you know what is creating the FFS files? Inspectors? Swap / temp files? Rejected features?
jugoslaviaa
  • Mar 11, 2020 9:51 AM UTC
No, I don't know. Does this screen shot help? @david_r
  • Mar 11, 2020 10:04 AM UTC
