Is FME able to read Civil 3D alignment station labels?
  • Jan 13, 2021 10:25 PM UTC
  • 199 views
I'm seeing the following lines in the Translation Log:
AutoCAD Reader: Entity type of 'AeccDbAlignmentStationLabeling' found, but not supported. Skipping entity
AutoCAD Reader: Entity type of 'AeccDbAlignmentMinorStationLabeling' found, but not supported. Skipping entity
I'm reading a .DWG in as an AutoCAD Civil 3D format file. Am I interpreting this correctly that station labels are not supported by FME?
@sarahbalabanov​  Unfortunately, as of FME 2020, the FME AutoCAD Map 3D reader does not yet support AutoCAD Civil 3D alignment station labels.
chrbalm
Forum|alt.badge.img+8
  • Jul 17, 2024 9:13 AM UTC
Is this still the case, as we are receiving the same error code in 2023.1
ali-safe
Forum|alt.badge.img+24
  • Jul 22, 2024 8:56 PM UTC
Hi, @cbalmbra1.
FME doesn't currently support these entity types. We have this backlogged [FMEENGINE-68243] for possible support (with enough demand). Also, could we request from you sample data containing some of these entities? Thanks!
crystalwang
Forum|alt.badge.img+31
Hi all,
The AutoCAD Civil 3D Reader can now read alignment station labels (FMEENGINE-68243).
Thank you for your patience and apologies for the delayed update! Please install version 2025.0 or newer at https://fme.safe.com/downloads/ to see this issue resolved.
