Is anyone successfully using FME 2018 with Oracle 18?
  • May 8, 2019 2:51 PM UTC
  • 68 views
gemini
Is anyone successfully using FME 2018 with Oracle 18? I can't find information on whether or not Oracle 18 is supported.
rahulsharma
Forum|alt.badge.img+12
Hi @gemini
We have not officially tested the scenarios, but one of our customers do have the Environment set up in Test stage(primarily using ArcSDE Geodatabase) and there are no reported issues on that front.
gemini
  • May 9, 2019 7:25 PM UTC
Hi @gemini
Hi @rahulsharma,
That is good to hear. We will also be working in the ArcSDE Geodatabase environment. I'll let you know how our testing goes.
rahulsharma
Hi @gemini
Sounds good @gemini, Just want to add, you may be already aware of this you will require a patch installed for both ArcGIS Desktop and ArcGIS Server in order to connect o Oracle please find the download links https://support.esri.com/en/download/7675
Please use Oracle 18c Client software as well (not sure if there are any restrictions but just good practice).
