Installing ArcGIS Pro on FME Server - FME Server Web Interface is down! SOS!
  • May 7, 2020 5:58 AM UTC
  • 49 views
We have FME Server 2019. I want to run some python that uses arpcy from ArcGIS Pro.
ArcGIS Pro installation requires Microsoft dot net 4.8. I have installed it and restarted the server machine.
Now our FME Server web interface did not come back up. FME server seems to be running. But we can't access the web interface.
1. How do I fix the web interface for FME Server? Is it dot net that causes the problem?
2. Has anyone successfully used arcpy from ArcGIS Pro on FME Server?
Best answer by gazza
We've worked with @lidiad this morning to fix this issue. As far as we can tell when FME Server was installed the IIS service was stopped but not disabled completely. A reboot of the machine restarted IIS so port 80 wasn't available for FME Server.
gazza
  • May 8, 2020 1:46 AM UTC
