IFC to Minecraft : some IFC components don't translate to pointcloud
  • Jun 16, 2019 5:10 PM UTC
  • 55 views
Hello !
I am trying to import an IFC model into Minecraft, but some parts are causing a fatal error :
PointCloudCombiner___VectorMerger(VectorToPointCloudFactory): The input geometry could not be converted to a pointcloud
A fatal error has occurred. Check the logfile above for details
I get this error with my own file, but I also get it with the file from this article.
More specifically, these two readers are causing the problem : IfcCurtainWall and IfcWallStandardCase. When I disable them, I get the desired output, minus these two elements.
0684Q00000ArE4qQAF.pngthis is what I got with my successfull export, you can see that the walls are missing
I'm very new to FME, so I must be doing a basic mistake. Can someone help me figure out which one ?
Thanks !
  • Jun 20, 2019 3:43 PM UTC
Hello, I am still completely stuck with that issue.
If someone can confirm that the file is working, or reproduce the error, it would already be of great help to me !
Here is the link to the article again (personnaly I can't click on the previous one for some reason):
https://knowledge.safe.com/articles/1064/how-to-make-minecraft-worlds.html
And the direct download link for the file :
https://s3.amazonaws.com/cdn.safe.com/fmepedia/attachments/minecraft/IFC_arboleda2minecraft.fmwt
