IFC to Cesium 3D Tiles - geometry colors disappearing
  • Dec 11, 2019 3:57 PM UTC
  • 89 views
Hello everyone,
I recently updated to FME 2019, since then the IFC - Cesium3DTiles conversion does not preserve geometry colors (it was working fine with FME 2018).
I think the problem comes from the Deaggregator. When I inspect the IFC, colors are preserved, but they disappear right after the Deaggregator.
Has someone got into the same issue ?
Thanks
sj
  • Aug 10, 2021 10:56 AM UTC
Can you share your script?
danminneyatsaf
Forum|alt.badge.img+13
Hi @seyjoo​, would you be able to provide the build number of your FME 2019 and the build number of your FME 2018? This will help us to see if there were any changes to the Deaggregator since FME 2018. Also, would you be willing to share sample data and a copy of your workspace for us to test? In the meantime would you be willing to test this workspace using the latest build to see if the problem still persists? You can find this on our Downloads Page.
Here to help, Dan.
