If I use a PostGIS Reader, to inspector, on a table, it shows the geometry. If I use a SQLCreator using POSTGIS format, doing a select * from same table, it shows fme no geom, is that normal for a SQL to not show the geometry ?
  • Feb 23, 2023 2:00 PM UTC
  • 75 views
mferwerda1111
Participant
Forum|alt.badge.img+54
  • Feb 23, 2023 2:47 PM UTC
You may need to explicitly specify the geometry column in the sql statement. I've found in the past that if there are multiple geometry columns or if the geometry column is named in a slightly non standard way
mferwerda1111
Participant
  • Participant
  • Feb 23, 2023 7:59 PM UTC
Yep, that seems to be it, thanks
