Identify the cell information XLS
  • Nov 25, 2015 7:09 PM UTC
  • 59 views
danilo_fme
Forum|alt.badge.img+58
Hello, i would like to get the cells information on table XLS.
For example, i know that has a format attribute in xls reader ( xlsx_row_id ) but i need too the information columm. The image below is G 14, but how can i get it with FME wie a value attribute? Thanks.
pratap
Forum|alt.badge.img+12
  • Nov 26, 2015 6:16 AM UTC
Hi, Column information can be treated from attribute header in your reader. Pratap
gio
Forum|alt.badge.img+15
  • Nov 26, 2015 11:58 AM UTC
If you want to use G14 to locate the value, you can set "Field Names Row" to 0 If you don't want to keep the header row, set "Cell range" to start from row 2, as row 1 has the headers. Now u have attributes A,B,C etc. With row_id's. You can do this in the reader Parameters. Another way would be to use a "attribute exploder."
danilo_fme
  • Nov 27, 2015 4:59 PM UTC
Thanks @pratap and @gio
