I get an error saying saying my shapefile writer cannot be over 2gb
How do I write a shapefile that is larger than 2gb? It has to be possible right?
Best answer by jdh
Actually no. That is a limitation of the shapefile specification which is from the 90s. I suggest you tile your data into regions or look at ways to reduce the size of the data (number of vertices, precision of coordinates etc)
View originalThis post is closed to further activity.
