?How to write to esri file geodatabase that needs to be created
  • Oct 17, 2017 2:21 PM UTC
  • 455 views
wil
Forum|alt.badge.img+5
I like to write the ouput of a transformer to a new esri file geodatabase using FME 2015. I use the Writer Esri Geodatabase (File Geodb API) and for Parameters a template is asked. I point to a Template.gdb
Next is again asked for a gdb but if the fgdb does not exists yet, the same applies for a Dataset. How to import into a new fgdb and new feature class with FME 2015.
Best answer by erik_jan
In the writer you can specify a new name for the GDB.
FME will automatically create the GDB if it does not exist.
Just start typing here:
erik_jan
Forum|alt.badge.img+26
  • Oct 17, 2017 2:33 PM UTC
