How to write multi-columns results to csv/txt as multi-lines ?
  • Jan 15, 2020 9:45 PM UTC
  • 6 replies
  • 82 views
Hey there,
I'm new to FME, sorry if it is a newbie question.
My pipeline result is the following:
I would like to create a text file with the following structure grouped by Template_Prefix and Template_AttributeList:
:Template=$CM_FT_IndexBi
:TagName, Area, DailyInstantVolume.Direct.PV.InputSource, ......etc
<content of line#1 column "Value" here>
<content of line#2 column "Value" here>
<content of line#3 column "Value" here>
:Template=$CM_G_VV
:TagName, ActiveEnergy.PV.InputSource, Area, Description......etc
<content of line#4 column "Value" here>
<content of line#5 column "Value" here>
<content of line#6 column "Value" here>
<content of line#7 column "Value" here>
:Template=$CM_PT
....etc...
How would you approach it ?
Thank you for your help !
Best regards,
Oli
erik_jan
Forum|alt.badge.img+26
  • Jan 15, 2020 10:07 PM UTC
Have you tried using the StringConcatenator transformer?
Or the Text Editor in the AttributeCreator.
Both should have the possibility to create multi-line attributes.
Then write that multi-line attribute to the text file (name by default text_line_data).
Hope this helps.
  • Jan 15, 2020 11:07 PM UTC
Hi @h2o2, if I could understand your requirement correctly, this workflow might help you. Be aware that you need to set the connection runtime order at the output port of Attregator properly (right-click on the ourput port > Set Connection Runtime Order).
  • Jan 16, 2020 2:20 PM UTC
Excellent ! Arigato Gozaemashita.....
This was exactly what I expected and I learnt a new feature also.....Thank you for taking time for making a clear mockup!
PS: Just struggling to find the "Connection Order" property that only shows up once there are at least two subsequent transformers (it makes sense actually)
Thank you.
  • Jan 16, 2020 2:22 PM UTC
Hope this helps.
I'll have a look into those ones. Thank you for taking time to respond...
  • Jan 16, 2020 3:02 PM UTC
Short side question. It looks to insert extra "Carriage Return" characters (0x0A) although outputs just before the Text File Writer look OK. I don't see any reason nor parameters to filter it.....
Is this an expected behavior ?
It inserts 3 carriage returns at each new Template_Attribute_List:
  • Jan 16, 2020 3:21 PM UTC
OK. I got it. I inserted an extra AttributeManager to Trim the AttributeList text_line_data prior to the File Writer.
Looks perfect now. Thank you again
