How to pass/get output from a workspace to fmeserverjobsubmitter
  • Dec 30, 2014 8:38 PM UTC
  • 45 views
HI All,
How to send an output from a workspace to fmeserverjobsubmitter.
For Instance I am having a workspace which checks if a field exists in a feature class if not then notify the user.
If I publish this workspace in the server and use it using fmeserverjobsubmitter how can I access the output
How can I achieve this ?
Thanks
  • Jan 5, 2015 4:23 PM UTC
in the workspace that is called by the FMEServerJobSubmitter, you will have to define one or more published parameters that will receive whatever value you want to transmit.
When you republish this workspace, you can re-configure the FMEServerJobSubmitter on the calling side and it will let you assign attributes to the published parameters on the called workspace.
See also here: http://fmepedia.safe.com/articles/How_To/FME-Server-Workflow-Management
David
