How to map field names as separate feature values?
  • Sep 20, 2022 2:32 PM UTC
  • 65 views
Currently, I have a dataset which looks like this:
imageI am wanting to produce something that looks like this:
imageRather than having each different activity displayed as a separate field name, I simply want to convert this into a single field name "Activity" then list the different activity types as a value on separate rows instead of the field header. I then want to apply the relevant frequency field to each activity.
Anyone have any ideas?
Thanks in advance
Forum|alt.badge.img+54
  • Sep 20, 2022 3:03 PM UTC
The AttributeExploder should get you most of the way there
imageYou will need to filter out some of the features afterwards and remove the original attributes but that should be straightforward.
  • Sep 21, 2022 1:53 PM UTC
Just what I needed, thank you :)
