How to insert Textformat(.txt) and Excel(.xlsx) formate data into smallworld by using FME.
  • Dec 14, 2015 1:20 PM UTC
  • 90 views
I ahve two formates of data text(.txt) and (Excel(.xlsx) The data is in bellow form.I want to insert this data into smallworld by using FME.
The data Formate as bellow in .Txt and Excels.
pratap
Forum|alt.badge.img+12
  • Dec 14, 2015 1:46 PM UTC
By using X & Y values, creation of point geometry is required?
Pratap
mark2atsafe
Forum|alt.badge.img+59
Pratap
Yes, using the VertexCreator transformer.
erik_jan
Forum|alt.badge.img+26
  • Dec 16, 2015 7:23 PM UTC
Or using either the CSV reader (for text) or Excel reader (for XLS) you can specify attributes as being the X- and Y-coordinates. That avoids having to use the VertexCreator.
erik_jan
  • Dec 16, 2015 7:39 PM UTC
And on the Writer side you can use the SpatialBiz plug-in for SmallWorld. This will allow you to write data from FME into SmallWorld databases.
http://www.spatialbiz.com/spatialbiz-plug-in.html
