how to get multicurves in autocad
  • Apr 20, 2016 1:33 PM UTC
  • 95 views
ddecoene
Forum|alt.badge.img+7
Hello,
i have a shapefile containing lines (and data), some of them are viewed as IFMEMultiCurves containing several FMElines. When i get these into autocad, they are inserted as blocks with data. This is not ideal for me, but i could work with this. When i want to convert these back into shape file I not able to recreate the original shapefile. (I Get all of the individual FMElines, so far more objects than the initial shapefile).
Is there a way, to keep these Multicurves together when converting back to shapefile?
Best answer by pratap
Do you mean that you want back same number of features when you perform w3055-arc-shp2dwg.dwgdwg to shp?
If "yes" then see the attached workbenchacad2shape.fmw
Pratap
pratap
Forum|alt.badge.img+12
  • Apr 21, 2016 4:26 AM UTC
Pratap
ddecoene
  • Apr 21, 2016 7:37 AM UTC
Pratap
Thanks for your answer, never thought it could be solved that easy.
