How to export smallworld data into ESRI shape using FME?
  • Dec 19, 2017 3:33 PM UTC
  • 201 views
Dear Supportteam,
I am trying to export smallworld data into ESRI shape files by using FME. I created workbench by taking smallword as reader and ESRI shape file format as writer.
While click on run it is created .shp and other supported files.But it creates only Attribute filelds without data. The data is not expoerted into shape file.
Request you to please provide detailed steps to exporting smallworld data to ESRI shape.
Actually i followed "Smallworld-Pathway-Training-2015" documentation for creating workbench.
But the data is not getting exported. I m trying it on Cable dataset.
Thanks in advance.
Thank you.
mgeomaticien
  • Dec 19, 2017 4:49 PM UTC
You can put a capture of your workbench please ?
erik_jan
Forum|alt.badge.img+26
  • Dec 19, 2017 5:28 PM UTC
Looks like a case of non matching attributes. Usually attribute names in Smallworld are lowercase and in Shape uppercase. If you right-click the link you have the option to "Autoconnect attributes". That might help in your case.
fmelizard
Forum|alt.badge.img+22
  • Dec 19, 2017 10:43 PM UTC
Hi @golugury, can you confirm that features are being read from the Smallworld Reader? If you were to connect an Inspector and run the workspace, do you all the features in the Data Inspector?
