How to download server logs for given jobId?
  • Mar 25, 2014 4:31 AM UTC
  • 87 views
   i have run 200 jobs on server. I need to download log files for each job. I can manually go inside each job and download log and save it. But it is very time consuming.
Is there any way i can use FME Desktop code to download logs per jobId from server?
Thanks.
Subrat
  • Mar 25, 2014 6:47 PM UTC
did you try at the FMEServerLogFileRetriever transformer?
David
dbaldacchino1
Forum|alt.badge.img+14
David
Thanks for the tip! I was wanting to do a search in a bunch of logs and this allows me to download all as an attribute and perform a search or regex on the logs.
