How to Delete from Geodatabase
  • Jun 15, 2016 4:27 PM UTC
  • 250 views
I am using the Esri Geodatabase (ArcSDE Geodb) writer and unlike the Oracle writer, there is no Writer Mode dropdown so I can select DELETE. How do I delete records from a geodatabase?
Thanks
pratap
Forum|alt.badge.img+12
  • Jun 15, 2016 5:46 PM UTC
You have to use db_operation as delete and you have to select the writer option in fme options as delete instead of insert
  • Jun 16, 2016 7:27 AM UTC
@pratap is on the right track, but the attribute is called fme_db_operation and you can read more about it here: https://knowledge.safe.com/articles/830/incremental-database-updates-using-the-fme-format.html
On the ArcSDE Writer, the mode is set on the writer itself, and not on the individual feature types, you can set it in the Navigator pane:
