How to create a INSPIRE GML without the gml:boundedBy-tag
  • Oct 12, 2016 9:21 AM UTC
  • 7 replies
  • 118 views
I'd like to create a inspire GML-file (using the inspire GML writer) without the <gml:boundedBy>-tag.
<gml:boundedBy> <gml:Envelope srsName="EPSG:28992" srsDimension="3"> <gml:lowerCorner>96465.102 471796.29 0.00</gml:lowerCorner> <gml:upperCorner>145855.225 563146.105 0.00</gml:upperCorner> </gml:Envelope> </gml:boundedBy>
Is there a way to generate such a zipped gml (with the INSPIRE gml writer) without the above text/tag. How do I prevent my workbench from generating this tag.
Thanks in advance.
Bas Boers
Best answer by takashi
Hi @bas_boers, just an idea. If you write the data into a file with the FeatureWriter (Format: INSPIRE GML), I think you can delete unnecessary elements from the resulting XML with the XMLUpdater transformer.
  • Oct 12, 2016 9:42 AM UTC
itay
Forum|alt.badge.img+19
  • Oct 12, 2016 10:51 AM UTC
Hi @bas_boers, In the past I had to apply something very similar to the idea @takashi mentions, I am afraid that it is not possible to accomplish with the writer.
  • Oct 12, 2016 11:31 AM UTC
Thanks @takashi and @itay for your replies,
My problem following takashi's suggesion is that the gml:boundedBy-tag is no attribute that can be deleted using the xmlUpdater. I'll try another type of GML-writer instead to transfer my data to IMKL2015 application schema. Maybe a nonpreferable solution lies in altering fme's gml config-files??
itay
  • Oct 12, 2016 11:34 AM UTC
I seem to remember using the XML Templater to create the result gml and not the writer, this gives you total control over the resulting schema. However it is initially more work....
  • Oct 12, 2016 12:29 PM UTC
If my understanding is correct, the "gml:boundedBy" is an XML element and I therefore think the XMLUpdater can be used to delete the element easily. This is a simplified example.
  • Oct 12, 2016 2:06 PM UTC
thanks a lot @takashi,
your solution works. I mad a mistake implementing the first time, but the example helped.
Regards.
deanatsafe
  • Mar 27, 2017 6:09 PM UTC
@bas_boers Another way to do this is to create a FeatureCollection feature and make sure it has no boundedBy geometry on it. Or you can set the boundedBy geometry to null and that should cause it to be dropped. This works as of FME 2017.0. See outboundedbytest.zip
